Order Ford 8N Parts Online
8N tractor
Ade
08-21-2004 10:07:23
What is the lever on the right side of the seat used for? What position is it surpose to be in,forward or back?
Rob
08-21-2004 10:48:09
 Re: 8N tractor in reply to Ade, 08-21-2004 10:07:23
It's the position control lever. If you're using a draft impliment put it down into draft control mode and attach the top link to the top hole if a light draft impliment, center hole for medium draft and bottom hole for heavy draft impliment (plow).
If you want to maintain the position of an impliment then put the lever up into position control mode. All the control will be in the top 3 inches of touch control with the lever up.
