Order Ford 8N Parts Online
8n overhaul
r.keller
08-22-2004 06:33:07
1have a 51 or 52 when installing the liners should they be flush with the block or stick up a little
Bob
08-22-2004 12:21:17
 Re: 8n overhaul in reply to r.keller, 08-22-2004 06:33:07
When sleeves protrude about the block, it is called "Sleeve Standout", and this helps to provide a good seal to the head gasket, and puts pressure on the sleeve to prevent it from trying to move up and down with the piston. Almost all sleeved engines have a spec for at least a thousandth or two of standout. However, if the sleeve were to go down beyond flat with the block to actually being recessed, you you definitely expect problems.
The I&T FO-4 calls for .001" to .003" of sleeve standout when boring a block originally sized for steel sleeves to accept cast iron sleeves, so it seems reasonable to expect to see sleeve standout within this range on any "N" sleeve.
Rob
08-22-2004 06:48:07
Stick up some don't sound right.
r.keller
08-22-2004 06:55:21
 Re: 8n overhaul in reply to Rob, 08-22-2004 06:48:07
this is what ithoutht wheni say stick up alittle maybe .005 is only on #2 when removed was very hard to get out
Rob
08-22-2004 07:01:41
 Re: 8n overhaul in reply to r.keller, 08-22-2004 06:55:21
I've never had to deal with that but if I did I might take my 2"x6" double-sided wet stone and hone that some to get it flush.
I'd make sure I couldn't drive that sleeve down some first.
