Draw Bar
Sal
03-02-2001 05:46:33
Right now I have my draw bar off since I have a blade on for snow plowing...with the draw bar on it gets in the way and I can't spin the blade around.
The draw bar is attached by a pin that seems to have a spring load on it, this is located under the rear x... I am surprised that the pin has not come out on me when it is in...what do you think about drilling a hole in the head of the pin and cabeling it to the N in some manner? Or should I just make sure I have a good spring on the pin.
Thanks.
Jimp CO
03-02-2001 08:47:29
 Re: Draw Bar in reply to Sal, 03-02-2001 05:46:33
Sal, if the pin drops far enough below the hole. you could just drill a hole in it and put a keeper pin in it like the ones used on trailer hitches. They come in all sizes. 1/8" would be plenty large.
Sal
03-02-2001 09:10:47
 Re: Re: Draw Bar in reply to Jimp CO, 03-02-2001 08:47:29
That's what I was thinking. The pin has a about 1/2"-5/8" head to it...about 1/4 the thickness of the dia. of the pin...looks a bit like a thumb screw end...put it in the drill press and set the hole...since there is no collar to it I can chain it to the underside of the N.
Thanks
chuck
03-02-2001 08:13:02
My drawbar uses a lynch pin to hold it in and I never worry about it coming out. Also, I have several position holes in the drawbar and I use one that puts it far enough in so that it only gets in the way of things that use the PTO. I can spin my 6 foot Ford backblade 360 degrees with the drawbar in place. The only drawback to putting the drawbar in that far is that in reeaally hard backing up turns I can hit the trailer tongue with the tires. However, this is somewhere near the 90 degree point and rarely a problem-but a real suprise when it does!
chuck
436244
sal
03-02-2001 08:36:10
 Re: Re: Draw Bar in reply to chuck, 03-02-2001 08:13:02
I don't see anyway to hook a lynch pin in there, wasn't desgned that way.
Even if the draw bar is shortened up all the way my 7' blade still hits.
I am still thinking about drilling a hole and adding a chain/cable for security.
Thanks
