Pic, Tree limb chipper with cat 1 lift?
Philip
08-26-2004 04:50:02
third party image
Hello Mike, here is a post I put in a couple years back. I suggest a chipper with a high discharge, not one that discharges on the ground. Contact me if you have any questions. Philip. I finally got to use my PTO chipper this weekend. I had a work day at my house on saturday, 5 guys showed up to trim limbs and cut trees. I ran the 8N for 6 straight hours with the chipper. The chipper is a Bearcat model with 5" capacity. The 8N and the chipper worked well together. It amazes me that my tractor, designed in 1938, can uses use implements purchased in 2002. What a great design by Harry F. The chipper has a 120 pound flywheel, lots of inertia, does not take much power to turn. When you put in a 5" branch, the rpm's drop, the governor kicks the throttle plate open, the engine starts poppin, and the rpm's come back up, just like it is suppose to work. Neat to stand back and see. The chipper is a nice tool, but it will work you to death. Philip.
