Type and amount of oil
Pigfarmer
08-27-2004 06:49:00
I know this probably will sound dumb, but I know nothing about Fords. I would like to know what type motor oil and hydraulic oil does a 8n use. I also need to know the amount it requires. Thank you to anyone that helps me. It is appreciated.
Jeff-oh
08-27-2004 07:19:22
 Re: Type and amount of oil in reply to Pigfarmer, 08-27-2004 06:49:00
Use GL-1 90 Mineral oil in the back end. NAPA part number 65-205 runs ~26 per 5 gallon.
Wal-mart no longer caries the GL-1 as their supplier stopped making it last year.
Tractor Supply carries Ford Transmission Fluid which is reportedly a GL-3 for around $36 /5gal.
Shell oil makes shell Dentax which is a GL-1 for around $37/5 gal.
Latham Auto Parts, an independent store in southern Ohio has GL-1 for $18.00 5/gal.
John IL
08-27-2004 07:07:13
The original spec Hydraulic oil was 90wt GL-1 mineral oil. 4.5 - 5 gals.
John
Steve (Magnolia, TX)
08-27-2004 07:02:28
You"ll open up a whole can of worms on the type!! I really believe that it"s more personal preference (along with tractor condition) than anything else. I used to use ND-30, before I rebuilt the engine (of my 1950 8N). Now I use 10W-30.
Capacity (with a filter change) should be 6 quarts.
HTH
Steve
08-27-2004 07:25:15
 Re: Type and amount of oil in reply to Steve (Magnolia, TX), 08-27-2004 07:02:28
I must"ve overlooked the "hydraulic oil" part of your question. My response covers engine oil. Everybody else has got you straight on hydraulic oil. I buy my GL-1 at Tractor Supply. 5 gallons for ~$40.
Steve
