Hyd. oil for loader pump
Arrowhead
08-27-2004 10:48:03
I have a Wagner loader with a crankshaft driven pump. The loader hydraulic system is completely separate from the 8N's hyd. system. Can I use power steering fluid or type F ATF to get me by for a few days? One of the loaders cylinders is leaking and needs a rebuild. It's a long ways to town and I have work to do. I have gallons of ATF and no use for it.
Thanks for all the good help here.
Russ in SoCal
08-27-2004 12:54:38
 Re: Hyd. oil for loader pump in reply to Arrowhead, 08-27-2004 10:48:03
Arrowhead,
My Ford loader calls for M2C-41. I have no idea what the characteristics are. So, if I really needed to, I"d use the ATF or M2C-134D or Crisco oil or..... Then, when I was redoing the cylinders, drain and reservice with the proper oil.
Russ
