keeping it original??? replacement or reproduction
robert t.
08-29-2004 21:43:12
when are replacement parts not original? if I replace sheet metal on my jubilee is it still considered (all original)? i currently have the original hydraulic hoses on the loader- is replacing them with new hoses O.K. - I guess I could go on and on but you probably get the idea.
thanks for any help you can share.
John,PA
08-30-2004 05:00:35
 Re: keeping it original??? replacement or reproduc in reply to robert t., 08-29-2004 21:43:12
There is a "life" to a lot of parts on tractors, and, most things mechanical. For instance, gaskets, rubber hoses, belts, and most importantly parts that are exposed to water and the elements.
When buying a piece of equipment, the vintage of the N's, I would prefer that certain things would have already been replaced with the best quality replcement parts available. For instance, the radiator, clutch plate, etc.
Sheet metal is cosmetic. Like all cosmetics, it can make or brake a "SALE".
Hope this helps. John,PA
souNdguy
08-30-2004 04:04:22
If you get down to the nitty gritty, I feel that all original pretty much refers to all bolt on parts that came with THAT tractor from the factory, With the exclusion of wear parts... For instance, clutch, brakes. I would also extend wear items to tires, and bushings/bearings, though i have certainly seen examples of tractors with original rubber that was very pampered / low hours and had decent oem rubber.
Depending on how you want to 'grade' the tractor, I think the next best thing to an original part, is a correct vintage replacement part from say.. a salvage yard.. or NOS dealer. Next would be a correct aftermarket 'like original' replacement part, and finally a correct replacement part from an aftermarket source that functions like the original.. but does not specifically look like the original... like oem steering wheels that are a tisco 'replacement' part.. but do not specifically look like the original.. etc.
Unless I was showing for 'points' I think that I would in most cases prefer new/rebuilt parts over a worm original item that would give me 'usability' problems.
Just my opinion.
Soundguy
hvw
08-30-2004 03:46:56
Restore means different things to different people. I've restored lots of old junk. In the case of mechanical things it's not usually practical to keep all of the original parts because they wear out and are meant to be replaced.
I doubt there are any 8N's for example with all of the original parts still in place. Tires and rims come to mind, radiator hoses, pistons etc. Even if you kept the original tin it's not going to have the "original" paint.
I think the idea is to replace what is neccessary with good quality components and make a good working machine that looks like it did when built. Often the new parts are better than the original. The show tractors are most certainly not original but are an excellent example of restoration.
