Order Ford 9N Parts Online
9n exhaust gasket
charlie Mo
08-30-2004 17:46:58
when installing exhaust gasket on a 9n, what type of gasket sealer if any, do you use
Gaspump
08-30-2004 18:01:39
 Re: 9n exhaust gasket in reply to charlie Mo, 08-30-2004 17:46:58
I have found that the thin silvery metallic gaskets which I believe are furnished by TISCO will not withstand much hard work, they seem to decompose to powdery residue all too soon. Prefer the black fiberous thicker gaskets that I pick up at NH, they also are someones aftermarket but they seem to hold up quite well. Goop or no goop the gasket quality really is an issue here.
none . . . Dell (WA)
08-30-2004 17:50:48
Charlie..... ...no gasket sealant on exhaust manifold gaskets. Just use hightemp anti-seaze on the manifold brassnuts and torque to 27 ft/lbs..... ..Dell
Rob
08-30-2004 17:50:26
 Not any in reply to charlie Mo, 08-30-2004 17:46:58
Don't need any goop on that one.
