OK, did compression tests this evening. I think I even did it right: (almost)Cold motor, dry - 75 75 80 75 Cold motor, wet - 90 85 95 ? Couldn't get her to turn over enough for the last cyl wet. Grumble, ran down the battery. Will do again tomorrow after I get a chance to charge her up. I did notice the very middle head bolt (couldn't find any reference to a number) had oil around it. I couldn't see any easy way to get at it to tighten it down. Couldn't get socket past the tube which carries the spark plug wires. Is there a "correct" way to get at it? I may just wait 'till this winter when I have her apart to paint etc. and replace the head gasket. From what I have read, I'll likely add some MMO to each cyl and let her sit a couple of days and then redo the test. The motor doesn't smoke at all, haven't run it enough to know if I have any power issues, but doesn't seem like it. Only messed around with the blade on the rock lane for a short time. Any thoughts? Brian '48 8N 60986
