tube valve stem leak
8ngreenhorn
09-03-2004 02:57:34
I think I gots a leak around the base of the rear tube valve stem. Ya got an easy fix?
souNdguy
09-03-2004 13:42:39
 Re: tube valve stem leak in reply to 8ngreenhorn, 09-03-2004 02:57:34
Put a drop of water on the tip of the valve stem and make sure it isn't the core. If it is the core, replace it with one of those core tools.. might put some lube on the small plastic seat of the new one. If it still leaks.. try a metal cap with a rubber gasket in the end of the cap, and some thread pucky on it as a temp fix. If that does it.. you know the tube is shot.'
Like Dell says.. I've changed a tube at home.. but don't like to.. its much easier to take the wheel off and pay some big strong tire guy who does it all day and watch him do it in 10 minutes with all the neat tire specific tool, and pay a 15$ labor charge on top of the tube price rather than fight and cuss with it for an hour with a couple tire irons and spoons.. etc..
If you demount it yourself, check the rim.. I had to wire wheel mine, and then I painted it and sealed it with epoxy paint to give the tube a smooth surface.
I heard our tire guy say he once used 2-3 layers of duct tape on a badly pitted tractor rim before.. said he just rolled it out and around the contact area of the rim .. but not the bead area.. that he cleaned up decently with a grinder/wire wheel, so as not to mar the tire bead. Said he never saw the farmer back, so 'guesses' that worked.
Soundguy
Leroy
09-04-2004 05:30:12
 Re: tube valve stem leak in reply to souNdguy, 09-03-2004 13:42:39
I have that duck tape in a 2N Ford rear wheel for over 15 years and still holding and still using fluid and just had fluid put in 9N rear new tubes that were empty when I got the tractor, unless it is strictly a show tractor you should use fluid for safty
mikeT
09-03-2004 11:34:35
The air may just be escaping from around the valve stem, but the leak could be elsewhere in the tube.
The inside rim on my tire had large holes rusted in it that cause the tube to develop a leak. I had to get a new rim, tube, and got a new tire at the same time. $300 total after paying someone $25 to do all the dirty work. That doesn't count the half tank of gas used to round up everything. Mine did not have fluid in it per se, but had about 2 gallons of the nastiest water imaginable. Probably from years of condensation. Unless your going to be plowing with your tractor or using a front end loader, I would not put fluid in the tires. 500 lbs of weights on the back would work for a front end loader.
Dell (WA)
09-03-2004 07:06:06
Greenhorn..... .....new rear tractor tire innertube only $25 (cheap). Iff'n yer tube is that OLD that the stem is leaking, then the rest of the tube is probably rotton too and will tear when you try to remove it to patch the valve stem.
And while experienced tractor owners can and have replace tubes at home, I'd recommend you seriously consider the merits of having experienced AG-TIRE people do it. Haul the tire into the shop ...or... have a field service call at yer place. (consult yer yellow pages)..... ..Dell
Ron/PA
09-03-2004 06:03:21
Sure do, you can buy a valve stem that has a large patch on the bottom. If the rest of your tube is good, you just cut the old stem out, and glue this one on it like a patch. Put valve stem back through the rim and yer good to go. Contact yer local ag tire dealer. Ron
Rob
09-03-2004 03:09:50
I've patched leaks in smaller tubes with some of that tube-type slime tire patch goop.
