High oil pressure when cold
8nTN
03-03-2001 17:29:06
When I first start my 50 8n it pegs the oil pressure gauge at 50+ and goes down to 15-20 at warm idle. It has been this way since I bought it 3 yrs. ago. Is this something to be concerned over and any suggestions. Thanks for any help
Ed Gooding (VA)
03-04-2001 06:07:52
 Re: High oil pressure when cold in reply to 8nTN, 03-03-2001 17:29:06
Does it do it both in Summer and Winter? What weight oil are you using? If it only does it in cold weather and you are using 30w oil, switching to 10-30 in cold weather may be the ticket for you.
Hope this helps..... ..... Ed
'52 8N475798
Dell (WA)
03-03-2001 19:23:03
It wouldn't surprize me that your oil pressure relief valve is sticking from varnish when cold and that is why you are pressuring over 50 psi. You could blow the cap off your oil filter and barff everything onto the ground and the EPA will get your a$$ for environmental contamination. (grin) I'd remove and clean the ball check and yes, there is supppost to be a flat spot on the ball.
15-20 is reasonable hot oil pressure..... ...Dell
bg
03-03-2001 17:33:08
Cold oil is thicker than hot oil and this is normal for the gauge to read higher until the oil thins down once the engine warms up. The 15-20 at idle seems really good.
dave#1
03-04-2001 17:46:40
 Re: Re: High oil pressure when cold in reply to bg, 03-03-2001 17:33:08
That's right bg, Like Al says, Cold oil is as thick as "Peanut Butter"
LOL
later"belch"dave
