Reverse the fan?
mcgd mcgdogm
09-05-2004 19:33:34
Anyone ever try reversing the fan on an 8-N? It seems to me it would keep the leaves and chaff off the radiator if the fan blew air through it instead of pulling it through--even slightly warmer air from the engine side.
mcgd V
wittey
09-06-2004 12:40:22
 Re: Reverse the fan? in reply to mcgd mcgdogm, 09-05-2004 19:33:34
There is a picture of a screen on this page.
wittey
09-07-2004 07:51:35
 Re: Reverse the fan? in reply to wittey, 09-06-2004 12:40:22
It didnt let me add this in the link.
http://home.att.net/~jmsmith45/8nacc.htm
ZANE
09-06-2004 03:15:49
Just turning the fan over will not reverse the flow of the air. The fan will still blow backwards towards the operator but will be a lot less effecient because the air foil shape of the fan will be lost.
Even if you have a pusher fan that pushes the air forward you have to have screens on the sides and bottom of the engine to prevent the same chaf from just plastering itself to the inside of the radiator instead of the outside of the radiator.
You can make a pretty effecient screen from window screening and tie it to the head lights and other stuff to hold it loosely to the front of the tractor hood. It works best if you can allow some to go under the front of the hood to prevent it pulling chaff up when the front begines to clogg.
Zane
Zane..John,PA
09-06-2004 04:42:23
 Re: Reverse the fan? in reply to ZANE, 09-06-2004 03:15:49
Zane,
I recently did an insurance job for a neighbor in which I replaced the outdoor condensing unit with a matching "A" coil.
I went back to the residence to paint the "Armaflex" insulation that covers the suction pipe. We always paint the insulation with white oil based paint to slow down deterioration.
The customer had wrapped window screen around the condenser in hopes to keep grass clippings from being sucked into the coil. When the tenant mowes the lawn he always blows the clippings into the air conditioning unit.
I recommended to the owner that he remove the screen to eliminate too-high head pressures. I said that just wash out the unit from time to time with his garden hose.
The owner said that it was HIS equipment and he would RATHER leave the screen ON. OK, I voided the warranty on the equipment!
I informed the owner that the only thing that I would do, if it was my equipment, was to put a picket fence around the condensing unit to keep stray dogs and cats from "lifting their leg, or urinating on the coils.
Apollo
09-06-2004 06:56:38
 What's your point? in reply to Zane..John,PA, 09-06-2004 04:42:23
Screens have been used on tractors for years with no problems. There are some significant differences between tractors and AC units, and trying to compare the two is like comparing apples and shoelaces.
I see no problem with putting a screen over the front of the tractor to keep debris out of the radiator.
Daveo
09-06-2004 11:35:03
 Re: What's your point? in reply to Apollo, 09-06-2004 06:56:38
I don't know - I'd sure hate to risk voiding the warranty on my N.....
Depends...John,PA
09-06-2004 14:24:30
 Re: What's your point? in reply to Daveo, 09-06-2004 11:35:03
Depends on who sold you that "brand new radiator". (GRIN)
Dell (WA)
09-06-2004 00:23:07
mcgd..... ..actually its already been invented. Often times called a tropical fan. It kept HOT RADIATOR air from blowing back over the operator in the summertime. Theory was better'n practice; mostly because of engine obstruction to reverse flow of air, the tractor actually overheated with the reverse fan. Don't confuse the 6-blade reverse fan with the 6-blade tropical fan. Neather are now available from the dealer, just the 4-blade pull fan.
Ford Dealers often sold a fine window screen radiator accessory to stop fine airborn debris from clogging the radiator fins. This accessory is still available from N-Specialists parts houses..... ..... Dell
ChrisH
09-06-2004 18:18:24
 Dell: Have you heard? in reply to Dell (WA), 09-06-2004 00:23:07
When I started my apprenticeship, I worked with a great group of fellows that had so much information. Willie told me that a fan will PULL air through a screen with twice the flow of the same fan PUSHING the air through the same screen. This is why furnace fans pull through the filters (on residential) systems. And also why reverse fans are only for winter use on forklifts (they're not cooling as much) Chris
Willy-N
09-05-2004 19:41:10
Just reversing the Fan won't work it will blow the air the same way. You need a reverse air flow fan blade and yes it will help keep a lot of the junk out of the radiator and a lot of heat off you during the summer. I like the heat in the winter myself! Mark H.
