Order Ford 8N Parts Online
8n radius rod
philm
09-07-2004 06:47:54
i recently purchased an 8n, which has a lot of play in the front axle, so i will be replacing the axle pin bushing and possibly the axle pin.
i also notice a lot of in out play from the radius rod where it enters the radius rod socket/cap.
i am assuming this is not normal. short of purchasing new radius rods and or socket/bushings, how do i determine if the wear is in the ball end of the rod or in the socket? which tends to wear first? the rod end or the socket?
philm
09-08-2004 10:09:46
 Re: 8n radius rod in reply to philm, 09-07-2004 06:47:54
thanks to all, for the replies.
2 cents fixed it up.
don b
09-08-2004 07:07:21
Make sure the radius rods are perfectly straight.If they are, you can put a little piece of Teflon [comes in sheets,not the tape]in the socket.Teflon will work better than metal.I've even seen bottle caps and snuff can lids used.AND, if you want to replace the sockets,they are available. don
Dell (WA)
09-07-2004 08:04:04
Phil..... ...don't worry about which has worn first or the most. The radius rod ball socket is NLA and I don't think you want to replace the rod ball. Most just use a "shim" of soft copper or alumnium or plastic to take up the slack. Rememeber NO LUBRICATION..... ...Dell
don b
09-08-2004 06:58:42
 Re: 8n radius rod in reply to Dell (WA), 09-07-2004 08:04:04
Dell, there you go with that NLA stuff again.These parts are available from some places, maybe even the sponsors of this board.[grin] don
