Head Removal
Pitch
09-08-2004 03:07:04
Okay I finally decided that this would be a good time to change that bad head gasket before snow flies. Can it be done with the sheetmatal in place? Removing it is such a pain and I always end up dropping the grill on my shins.
Jeffery {OH}
09-08-2004 08:20:00
 Re: Head Removal in reply to Pitch, 09-08-2004 03:07:04
I am in the middle of doing it now. It is easier to see the top of the block to make sure there isn't stuff on the mating surfaces without the hood on. You can see what the top of the valves and pistons look like!
my 2 cents worth.....
Rob
09-08-2004 07:59:40
You might be on to something. Given that lifting the hood and moving it off to the side is a bear you might consider just lifting the hood straight up 6" or 8" or something. It could be blocked off the battery and the radiator or other wise.
Drain the gas so it's not heavier than need be, disconnect everything, and block up one end at a time back and forth. You never would have to lift that thing, and you could get room. For a headgasket change that might be ok.
Dell (WA)
09-08-2004 06:52:47
Pitch..... ...Iff'n ya gotts the early engine with studnuts, you CAN'T remove the head over the studs without first removing the sheetmetal. Took me and my 12 yo son 1/2 hr to remove the not heavy but AWKWARD hood and set it on some sawhorses. And the reason it took so long is because I was instructing in the manly arts of tractor wrenching (grin). Take the hood off, you'll be glad you did..... ..Dell
Wrench'n..John,PA
09-08-2004 08:29:12
 Re: Head Removal in reply to Dell (WA), 09-08-2004 06:52:47
Where I hail from, "wrench'n" is what you do with your clothes after you wash them. You "wrench'em, then hang them up to DRY!"
(GRIN)
Dell (WA)
09-08-2004 10:03:00
 Re: Head Removal in reply to Wrench'n..John,PA, 09-08-2004 08:29:12
yeah, he was a little young to take him wenchin' at the corner tavern (grin)
Dan
09-08-2004 05:00:44
I sure wouldn't try it. Ford made the hoods come off easy for this reason. After you drain the gas tank, it is only a 5 minute job. Gives you a good reason to check that in-the-tank filter as well and clean it up...
Good luck,
Dan
Pain..John,PA
09-08-2004 03:47:27
I really think that it would be more of a PAIN to remove the head WITHOUT removing the cowl (sheet metal). Might be a good time to also check over the fuel tank. Probably might be the last time you ever need to do it. John,PA
