M2C134D hyd fluid recommendation
Rob
09-09-2004 17:05:13
Went over to the New Holland dealer and asked the parts guy if he had a recommendation for the tranny fluid in the N, something in writing. He looked in his official New Holland what-to-use-for-lubes-and-fluids book and say '134D, all of those Fords are 134D, hundred series, N's, everything.' I say how about the bigger ones and he says 'everything....but I use 90 weight in my N.' I say 'what kind of 90 weight, GL-1 or 5 or what' and he says '80/90 weight. I don't know....gear oil.'
Asked about winter and he says never had any problem in these Kansas winters but parks it inside and it never gets below freezing.
souNdguy
09-09-2004 21:50:11
 Re: M2C134D hyd fluid recommendation in reply to Rob, 09-09-2004 17:05:13
Yes.. NH now recomends 134d oil as the 'blanket' answer to just about all of their hydraulic/transmission/diffy fluid needs.
The oem spec was 90wt gl-1 mineral gear oil.
The 90w oil works fine in warm climates, and is also great if your lift leaks a bit. It can be stiff in 0 degree weather.
134d oil is thin like 20w oil... great in winter.. not so great if your lift leaks..
I personally use the 90wt gl-1.. not to be confused with the 80w90 gl-5 oils that might damage yellow metals like the ones found in your expensive hydraulic pump. At 17 bucks a pial.. it is even cheaper than the common gl-5 oils..
Soundguy
