Broken tractor is a good thing
Arrowhead
09-10-2004 12:18:03
Last week I posted a message about my loader wreck. The four stinger pins broke causing loss of hydraulic power to the front pump.
The new parts are here already (thanks for the offer Hobo) and while the loader was off I painted the tractor's belly, hope Ford blue is OK.
Thanks to the info on the archives I am able to fix this with confidence. I'm glad to read Dell says I can change the front pulley without removing the front support and axle. And I can put a dog leash in the sparkie hole (no clothesline rope here) to prevent the crank from turning.
Thank you all for the great advice here and to Jim Cox for the generator parts. You guys make owning an 8N a real pleasure.
-Arrowhead
John Smith8Ns
09-10-2004 22:35:33
 Re: Broken tractor is a good thing in reply to Arrowhead, 09-10-2004 12:18:03
Ya better have a plan "B" ready to go. There's no way you can change the front crankshaft pulley without removing the axle support. Not enough room to get it off the end of the crankshaft.
Arrowhead
09-11-2004 13:49:31
 Re: Plan B in reply to John Smith8Ns, 09-10-2004 22:35:33
How right you are! I just figured that out. Plan B it is.
Jim.UT
09-10-2004 12:52:06
You might want to inspect your fanbelt while the loader is off. It looks easier to replace without the loader pump shaft in place.
