NAA Camshaft End Play
Ramrod
09-11-2004 10:11:37
Just about ready to lift the engine off, and noticed that the cam shaft spins easily with my fingers, but there is end play and a clack when it moves fore and aft. The cam shaft has bushings, yes? What gives with the end play, is that normal? I figure on removing the cam and crank and turning both during rebuild...
Thanks Guys,
Ramrod
MikeT
09-11-2004 16:03:46
 Re: NAA Camshaft End Play in reply to Ramrod, 09-11-2004 10:11:37
Camshaft end play on an 8N is supposed to be no more than 0.0004". Don't know about an NAA?
MikeT
09-11-2004 20:02:00
 Re: NAA Camshaft End Play in reply to MikeT, 09-11-2004 16:03:46
OOPS! 0.004", not 0.0004" !!!! 4 thousands of an inch.
TJ in MO NAA
09-11-2004 20:13:55
 Re: NAA Camshaft End Play in reply to MikeT, 09-11-2004 20:02:00
Ramrod, My Ford Shop Manual No. FO 19 for my NAA says the camshaft end play should be 0.003-0.007
I hope that helps.
regards,
TJ
