Don - I find it better to use an ampmeter insetad of a voltmeter. Regardless of whether it's a 12V or a 6V system, you should have about 4 amps (for a 4 cylinder engine with points) flowing in the coil circuit when the points are closed and the engine is hot. so, in a 6 volts 4 cylinder system, you need about 1.5 ohms total in the coil circuit when the engine is hot. That includes the resistance in the coil primary winding and in any other type of resistors in the circuit. In a 12V system you need about 3 ohms, total, in the coil circuit. 12V coils labelled with "External resistor not required" will have the 3 ohms in the primary winding and no external resistors are necessary. The ballast resistors are variable resistors. When they are cool, they have less resistance. This gives more current to the coil to make the tractor easier to start. As they get hot, the resistance goes up and the coil current goes down to approximately 4 amps. If you have a volt/amp meter, follow the user instructions on how to hook it up to get amperage readings. (put the two leads in series with the coil circuit and set it to read AMPS) Put the ampmeter in the coil circuit and rotate the engine by hand till the points are closed. If the reading is more than about 4 amps on a 12V system (with the proper coil), or more than 6 amps on a cold 6V system, then something is wrong. You could heat the ballast resistor with a heat lamp if you wanted to and take another reading. When it is hot you would want about 4 amps. With 6 cylinder engines with points you want 6-8 amps in the coil circuit.
