Order Ford 8N Parts Online
Frontend loader 8n
alan myers
03-04-2001 19:29:48
looking for picture or info on mounting 1 arm loader on tractor .need to know what mounting bracket looks like
Larry 8N75381
03-05-2001 08:04:14
 Re: frontend loader 8n in reply to alan myers, 03-04-2001 19:29:48
Your best bet will to be find the model tag on your loader so you know what model to look for. Then go to the link below and look for the manual for it. The N-Newsletter has an extensive archive of old manuals, so I'd be surprised if they do not have one for yours.
I suspect that you are going to have a problem putting it on an 8N, since I am sure it was not made for the N series tractors. I have seen one, but it was on a later model tractor, one that has threaded atttachment points (holes) on the "frame" for such things as loaders - the N-series does not have these threaded holes. So things, like the side attached mower, added brackets that hook to the tractor at the engine/transmission/differential flanges. They replace the existing bolts with longer bolts to account for the added thickness of the added frame.
Good luck on your "project". It should be intresting to see - one of a kind, I suspect.
Larry
