Susan..... ...valves get sticky 'cuz the oil hazzn't been changed often enuff. I'm glad you got your valve "unstuck" but its gonnna happen again iff'n you don't do something about it. Me? I'd put a quart of Marvel Mystery Oil in with the rest the engine oil and run it for about 1 hour and then drain the engine oil and change the oil filter. MMO is one of very few engine "additives" that actually work. BTW this is the same "Marvel" company that made your 9N's Marvel/Schebler carburator. I use 20-50wt oil for eazier cold engine starting and hot engine protection ...and... the DETERGENT ablility to suspend the sticky combustion by-products that turn into varnish that caused your intake valve to stick open. Ford recommends changing your engine oil EVERY FALL (or 200 hrs of operation). Sometimes descriptions of problems get garbled, and ignition is more common problem than stuck valves. I flunked mindreading, just ask my ex-wife of 32 years..... .....FWIW, Dell HTH...hope this helps BTW...by the way FWIW...for what its worth IMHO...in my humble opinion ROFL...rolling on floor laughing Theres a whole bunch of BBS shorthand and acronyms and there are actually "official lists" of commonly used ones published in various web pages. Some people use them to make themselves appear less pompous (ha!) others because it fits the casual conversational mode of bulletin boards; others because they want to appear part of the "in-crowd"..... ...Dell
