oil filler tube
twodogs
09-13-2004 08:52:53
Hey folks! I picked up an 8N about a month ago. I have oil coming out of the oil cap after I run the machine for awhile. I bought a new cap, but it didn"t make a difference. The tube itself has a baffle in it. My questions are - should the tube be filled with baffles? If so, how difficult is it to replace the tube? Do you have any other solutions to cure the leak?
souNdguy
09-13-2004 11:51:21
 Re: oil filler tube in reply to twodogs, 09-13-2004 08:52:53
Probably blowby.. but check your oil level.. if it is too much oil.. it will really splatter out bad..
Soundguy
Rob
09-13-2004 08:57:54
 That tube is fine! in reply to twodogs, 09-13-2004 08:52:53
Your piston rings are bad. Blow-by comes out that tube.
You don't believe me? Do a compression test: tester $15 at autoparts or Sears.
