Air Filter Housing Heart Disease
Lincoln
09-15-2004 16:01:29
I decided to clean my air filter today while I was replacing the manifold on my 8N, so I dropped the oil reservoir off and got to work. 3 hours later I've finally gotten the damn thing apart, and I've cleaned the wire mesh material real nice and everything else downstream of the oil cup. The problem is upstream from the oil cup; the tube running the length of the housing is suffering from some serious arterial blockage, I'd say it's a third of the original diameter. Further up, in the air space between this tube and the hole at the top that draws fresh air in, there are inches of gunk/sludge.
I've scrapped clean as much as possible with a screwdriver, but it ain't much. Before I go and buy a wire brush shaped for this sort of thing, I wanted to see if maybe someone here had a good method for cleaning these things. Thanks for any suggestions.
Now I'm off to find the guy who designed this this thing, so maybe I can force HIM to clean it--that is, unless he's already in hell damned to dismantle and clean 8N filter housings for eternity.
Lincoln
09-16-2004 20:06:07
 Re: Air Filter Housing Heart Disease in reply to Lincoln, 09-15-2004 16:01:29
Thanks all, I was really upset for a while there but it makes sense that it's not the design, but lack of maintenance.
I finally borrowed my neighbor's power washer and used the 15? jet to clean out my air filter housing. Yes, it was gunked up between the oil bath and the outlet to the carburetor, so thick and dense that it was hard to stick a screwdriver in it. The power washer cut through it no problem, so the filter is good to go now. I also cleaned out the wire mesh, which wasn't so dirty, and the air intake vent on the hood, which was missing the dust jar. I corked up the opening for the dust jar, since I don't operate in very dusty conditions I figure I'll hold off on buying a bracket.
Thanks again, this forum is an awesome place, my tractor wouldn't be in half as good of shape without you all!
Bob - MI
09-16-2004 05:45:24
Previous owner neglected to clean the filter when he should have and like many things the problem gets bigger with time. I would try soaking this in slovent since the sludge is to some extent oil laden. A parts washer would be handy here but a bucket with some kerosene would work ok too. A little manual agitation and some time should get you back in the seat quickly.
Rob
09-16-2004 05:33:19
 I'm with Zane. in reply to Lincoln, 09-15-2004 16:01:29
Those oil bath filters are great and they will keep you running when the conditions are extreme where a paper filter won't. Oil bath are cheap to keep too.
I don't what is in your filter. If I have it right your crud is between the air intake and the oil bath. It must not be oil. Has to be something sticky, maybe it's pollen. Try hot soapy water. It might wash right out. Soap and water doesn't work try a solvent. You probably have some paint thinner, try that.
It might have taken 50-years to get that way but I figure you'll give it better maintenance from here on out.
ZANE
09-15-2004 18:11:38
It's not the design that is the problem with the air filter. It is the maintenance that it didn't get somewhere along the line. This filter is one of the best air filters ever designed in my opinion. Beats the heck out of these modern paper sifters that they call filters. If they were on a tractor in dusty conditions they might pass air for about four hours most.
The N filter is self cleaning if it is maintained correctly. The oil that is in the cup is drawn up into the wire mesh when the engine is running and if the dust particles are not caught in the remainder of the oil at the bottom of the oil cup they will be caught as the air passed up through the oil covered wire mesh. When the engine is stopped the oil drains back down into the cup and deposits the dust it caught into the oil in the cup and it settles to the bottom. This is the reason that the oil cup has to be cleaned at intervals according to how much dust it is exposed to.
I am thinking that at some time your air filter was allowed to dry up most of the oil from the filter cup and the dust was able to continue on into the area where it would normally not go if maintained correctly.
Zane
