Pat..... ...to ears used to the whirr of modern 12 volt sewing machine starter motors, the whump-rump of the 6 volt flathead starter is veeery sloooww. Your low engine compression (Ford specs: 90 psi dry) is often bandaided by a conversion to 12 volts for a FASTER turning 6 volt starter motor (no, 12 volts on 6 volt starter doesn't hurt it) and subsequent faster and eazier starting. For the mechanically challenged, who don't want to do a $1500 engine overhaul for occasional tractor brushoggin' use, a $150 12 volt conversion can be a compelling reason. And STAYAWAY from electronic ignitions for squarecan frontmount ignition systems. Engine smoke is NOT VALVES, its rings. Me? I'd at least do a Marvel Mystery Oil treatment ($5 cheap) to make certain your rings are NOT STUCK. Seldom used OLD TRACTORS get sticky rings and loose their compression. Just add about 1-tablespoon of MMO to each sparkie hole (crank the engine for a couple of strokes to spread MMO around, wait for a day to give the MMO a chance to work before you start the engine) Pour the rest of MMO into the current crankcase oil and run the engine for about 1-hr, then change the oil and filter while HOT. After you change the oil, check your compression again..... ...respectfully, Dell a 12 volt advocate for the right reason That said, I haven't found the right reason for my easy starting 6 volt 52 8N, and I know how to do it right the 1st time.
