2N drag links/tie rod ends
DonIL
09-19-2004 16:30:58
Need to replace the above due to wear. I noticed that what"s on my tractor near the steering sector is all one piece with the connecting tube, but no one sells these anymore. Can I just get the front and back ends and use the 8N connecting tube?
Leroy
09-22-2004 19:39:18
 Re: 2N drag links/tie rod ends in reply to DonIL, 09-19-2004 16:30:58
Ferguson TO 20 & TO 30 will work, are the 3 piece have them on my 2N
don b
09-20-2004 07:17:47
No.....Front tie rods are available but the rears are not.If you want to replace the rears,you will have to buy the Naa rear tie rods and tubes, which are available.The 8n tubes are too short to use with the rear Naa tie rods.Any questions....give me a call. don
Jeb2N
09-19-2004 17:41:43
You are correct. The rear half of the 9N/2N drag link is one piece with the ball joint integrated into the tube. No way to replace it. YOu can replace the front ball joint (tie rod end). I ended up with one good side and one worn side when I went through my 2N. I ended up going to the salvage yard and purchasing a good used rod for fairly cheap. If you decide to go that route, be advised that they are right- and left-hand specific.
Jeb
Rob
09-19-2004 17:20:49
 Did you try New Holland? in reply to DonIL, 09-19-2004 16:30:58
Shows good part #'s in the book.
Jeb2N
09-20-2004 05:40:47
 NH ain't got em in reply to Rob, 09-19-2004 17:20:49
You can still buy new 3-piece drag link assemblies and sub-components, but the older 2-piece components are no longer available except for the front tie-rod end.
Rob
09-20-2004 06:14:37
 Re: NH ain't got em in reply to Jeb2N, 09-20-2004 05:40:47
He's asking if he can get three pieces. New Holland doesn't have 3 pieces for his tractor? Your post is confusing.
Jeb2N
09-20-2004 08:37:59
 Re: NH ain't got em in reply to Rob, 09-20-2004 06:14:37
I thought you were saying NH had the old style 2-piece sections. You are correct. The 3-piece is available, 2-piece is not.
Jeb
