Loose Steering on 1953, what normal
Randy NAA in Mi
09-20-2004 11:50:40
Working on my NAA, the steering wheel has 3 -4 inches of "play" (ie: I can turn the steering wheel almost 4 inches before the wheels turn). Is this "normal" amount of play in the wheel (suspect not)? What would it take to reparir? Thanks in advance for the information.
Leemo
09-20-2004 14:36:34
 Re: Loose Steering on 1953, what normal in reply to Randy NAA in Michigan, 09-20-2004 11:50:40
Like Rick said you can probably adjust it out using the adjustment on the steering gear box. Piece of cake !!
Good Luck, Lee
souNdguy
09-20-2004 12:04:49
3-4 inches is just a tad sloppy. If you can get it to 3 inches or under by adjusting the sector screws.. I'd be happy. Mine has about that much play. I know eventually it will need a steering rebuild.. I'm just not looking to do it now.
Soundguy
Rick H. Ga.
09-20-2004 12:02:12
Randy, the NAA has two adjusting screws (one on each side) on the steering housing that can adjust the slack out of the internal gears. The FO-19 manual gives a good discription on how to adjust the steering box. There are a few other items that can contribute to loose steering; worn draglink ends, worn spindle bushings and a worn front axel kingpin/bushing. HTH. Rick H. Ga.
