Order Ford 8N Parts Online
8N Clutch question (NOT stuck)
PNR123
09-21-2004 12:28:57
I picked up my clutch kit today for my '48 8N (Pressure Plate , Disc , Throw out & Pilot bearings) for $304CAD ($236USD) a bit pricey but I only had to wait one day and plan on changing it out in the very near future , my question is this : while she's split apart is there anything else I should do to the innards???
thanks again
SteveB(wi)
09-21-2004 13:51:29
 Re: 8N Clutch question (NOT stuck) in reply to PNR123, 09-21-2004 12:28:57
Check the ring gear and replace if needed.
Bob
09-21-2004 13:19:46
If there is ANY wear at all on the flywheel surface, have it ground. With that, plus the new parts, the old girl should be good for another 50+ years!
yes . . . Dell (WA)
09-21-2004 12:35:45
prn123..... ..yes, change your tranny input shaft OILSEAL $3 (cheap). Tip: use your 4-bolt removable tranny input shaft as a clutch ALIGNMENT tool at the same time..... ...Dell
PNR123
09-21-2004 12:50:36
 Re: 8N Clutch question (NOT stuck) in reply to yes . . . Dell (WA), 09-21-2004 12:35:45
Thanks alot Dell , hopefully everything will go smooth and she'll be useable again in no time , any hints to make the job go smoother , I'm kinda planning on blocking up the front half and braceing the engine from each side with 10' 4"X4"s to prevent it from rotating and using our big a$$ forklift at work to move the rear half with a sling around the bottom , does it sound like a good idea?
