clutch springs
ohio9nmatt
09-22-2004 18:40:19
I was wondering if anyone had any info on the clutch springs. I really do not want to buy a whole remanufactured setup as the surface is in good condition
I would like to replace the springs. They look like valve springs out of a chevy (almost) I was wondering if anyone had any info and if I could use a heavier springs as well
any info would help..thanks!
9nohiomatt
09-24-2004 12:22:06
 Re: clutch springs in reply to ohio9nmatt, 09-22-2004 18:40:19
my goof, I was talking about the springs inside the clutch pressure plate
Dell (WA)
09-24-2004 07:00:20
Matt..... ..replacing the shock coupling springs in the center hub of the clutch requires special compression tooling. And while you could probably rig sumpting up, why? NEW CLUTCH $50 (CHEAP)..... ...respectfully, Dell
