Strange washers found in Transmission case??
Alex Dula
09-22-2004 19:31:29
I am rebuilding my 52 8N and after cleaning out the gunk in the bottom of the case I found two washers. One was broken and the other was in good shape. I could not find this special type washer in the parts manual. It is about 2" in diameter with a D shaped inside cutout about 1 1/4" and has a notch on the outside opposit the longest flat inside that is about 1/4" wide and about 3/16" deep. Any ideas what this is?
I am getting ready to put the new clutch in and attach the engine which I rebuilt last year. Any suggestions would be appreciated.
Also I have misplaced the clutch arm pin (8N7533) which NH says is not made any more. Also misplaced the two 1/2" x 1 3/8" pins that hold the brake paws on the arms. It is terrible getting old!! I took it apart in 1998 and they are probably around somewhere.
Thanks,
Alex
ZANE
09-23-2004 06:41:02
 Re: Strange washers found in Transmission case?? in reply to Alex Dula, 09-22-2004 19:31:29
I am doing a little mind reading here. I think what you have found is some old starter drive parts but they were not in the transmission but in the clutch housing????? ?
If it is starter drive parts, don't worry, be happy. it is a common thing and won't do any harm. Throw them in the trash!
Zane
lonestarjeff
09-22-2004 19:50:22
Mine had a couple of knock-out plugs inside the clutch case.
Jeff
