Pete, Since you are "electrically chalanged" (grin) I would suggest that you talk to the Barkley"s and go back to the ORIGINAL 6V system. I say that because then everyone that can help you here on the board will know EXACTLY what you arte talking about because it is the original wiring system. That said, if you are going to stay with the 12V, then get something that has someone like the Barkley"s standing behind it so you have a place to ask your questions when you need help. I am more concerned with the comment, "Some of the connections get so hot they would burn your hand quickly." Hot connections are very BAD!! They should NEVER be hot. If they are hot then there is either too much resistance in the connection - not "clean, bright and tight!" - as you will hear Dell say over and over. OR the connection is carrying TOO much current - not good either - since that probably means that you are going to burn out something. MAN, you need new wiring! Pull that N into the garage and get after fixing it. The problem could be as simple as water around the distributer. A hair dryer may dry it out enough to get it started. Good luck, Suspect some more of the guys will chime in here as the day wears on. Larry
