Manure Spreader
CVRancher
09-24-2004 15:36:18
Do any of you fine tractor scientist have an idea on building a manure spreader for my 8N. I've picked up so many tips from all of you and have been able to keep my 8 running great. Since we've moved here three months ago I've found three other N's within one mile of my house that never seem to be used. Maybe I've found a new project.
Thanks for your help and great ideas.
Jim
Rob
09-25-2004 09:07:25
 I read that subject line and thought in reply to CVRancher, 09-24-2004 15:36:18
you were going to gossip about one of the regulars!
Have a fine weekend.
Russ in SoCal
09-24-2004 19:19:20
 Re: Manure Spreader in reply to CVRancher, 09-24-2004 15:36:18
CV,
Where you at? I got one in Rosamond that IS used. If you come up with a good plan, let me know. My wife"s two horses just won"t quit makin" the stuff.
Russ
CVRancher
09-24-2004 20:02:24
 Re: Manure Spreader in reply to Russ in SoCal, 09-24-2004 19:19:20
Russ, I'm just up 90th St. in Tehachapi. We have two horses also and they generate the need for one. I have a simple idea that should spread about 100 lbs.a load. Let me have your e-mail address and maybe we can talk about the spreaders.
Thanks Jim
Russ in SoCal
09-25-2004 09:12:53
 Re: Manure Spreader in reply to CVRancher, 09-24-2004 20:02:24
CVRancher,
It"s unblocked.
Russ, Shannon, Devil and Just-Tina
old
09-24-2004 18:04:42
If you watch enough of the auctions billets you should be able to find one with a spreader on it. I picked one up last week for $5 yes only $5 and it had 9 sheets of roofing tin in it. It had 2 bars missing in the box chain which was no big deal. I don't think you could build one at that type of price. I've seen them go for $5 up to $500 depending on the auction, go to a lot of them and you will find one very cheap
ZANE
09-24-2004 17:51:40
The dairy farmers around here were always breaking something on their manure spreaders when they tried to use it with frozen manure in it.
Somebody started making a spreader that was nothing but a big half drum with a big shaft through the top with chains welded to it. It was directly connected to the PTO. No gears or chains or gear boxes and it worked like a charm. Frozen manure didn't faze it. Worked just as good on frozen as loose.
It was the only machine that we sold that we wouldn't stand behind! :O)
Zane
MikeT
09-24-2004 16:54:12
You got any Tractor Supply Stores around? Go check their's out. Looks like they would be pretty easy to duplicate if you have a torch, welder, and sheet metal skills.
I lost my high school ring one day when loading our spreader with chicken poop. To this day, my wife says that I gave it to "that other girl".
Mr Bill No. Mn.
09-24-2004 18:21:11
 Re: Manure Spreader in reply to MikeT , 09-24-2004 16:54:12
you must have given it to one of those chicks. He He lol
