Generator oil cap location
jiminoystercreek
09-25-2004 18:47:18
Can anyone tell me the normal orientation of the oil fill hole and spring cap on an 8N 6-volt generator? Should it be up to hold the oil in or laying on its side like mine is?
Jim Cox
09-26-2004 20:40:09
 Re: Generator oil cap location in reply to jiminoystercreek, 09-25-2004 18:47:18
The common sense position is cap towards the sky. There is an old Generator ID book floating around the rebuilder's world that shows the oil cap on the bottom and the wick on the top of a 9N generator, but who says the guy taking the pics ever oiled a tractor? Dell is right as to the single hole on the bottom of the 8N10001 field case so a tab from the side dist genny mount will locate the genny. For front dist gennys, the rear bracked will only go on in one place, but like I said above, some folks can put them on 180 degrees out of position
Jim Cox
Rob
09-26-2004 10:46:05
 It's not suppose to be at 12 o'clock. in reply to jiminoystercreek, 09-25-2004 18:47:18
jiminoystercreek
09-26-2004 11:47:29
 Re: It's not suppose to be at 12 o'clock. in reply to Rob, 09-26-2004 10:46:05
Where's it supposed to be?
Rob
09-26-2004 12:05:06
 Front mount it will be at 1-o'clock or later in reply to jiminoystercreek, 09-26-2004 11:47:29
Side mount it will be 11-o'clock or so.
Those genny mounts are indexed so unless it was ham-fisted forced in there you don't have anything to figure out. Just assemble it to the index and it will be right. Depends on the belt and stuff.
Upper Peninsula,Mi
09-25-2004 19:46:59
The oil cup on my 9N's is on top and my F0-4 manual shows the 8 N's oil cup also on top.Ron
jiminoystercreek
09-25-2004 20:01:04
 Re: Generator oil cap location in reply to Upper Peninsula,Mi, 09-25-2004 19:46:59
Sounds like I need to loosen that bracket and roll that rascal up a bit. Thanks
Dell (WA)
09-25-2004 23:03:01
 Re: Generator oil cap location in reply to jiminoystercreek, 09-25-2004 20:01:04
Jim..... ..there is supposed to be a locating stud in the saddle of the left sidemount 8N gennny brackett that should orentate your oilcup into the vertical position..... ....Dell
