Order Ford 9N Parts Online
Transmission Retainer (9N7134 ) changeout??
Alex Dula
09-25-2004 19:13:24
I am getting ready to put the enginw back on the 8N and I thought I read on a post that it might be a good time to change the gasket (9N7086) in the transmission case I think? Anyway should I do this as there has been some leakage of fluid into this area when I took it apart. I think this is where it is comung from. If it is should I do it and can I just remove the four bolts and pull the retainer out without the shaft and gears falling down?
By the way the cam follower is still stuck in the arm (8N680) and I have not seen how to remove the arm from theshaft it is on.
Thanks,
Alex
ZANE
09-26-2004 07:15:30
 Re: Transmission Retainer (9N7134 ) changeout?? in reply to Alex Dula, 09-25-2004 19:13:24
You must pull the ram cylinder off the housing by removing the four bolts that secure it. Then you can remove the position linkage and place the link over a vice and drive the pin out or you can use a press and press it out.
Zane
yes . . . Dell (WA)
09-25-2004 22:58:29
Alix..... ..yes, pull the 4-bolts to the tranny input shaft and replace BOTH the tranny input shaft gasket p/n 9N-7086; and tranny input shaft seal p/n 8N-7052-A.($3 cheap) And nuttin will fall off or loose clearances when you pull your tranny input shaft outta the tranny.
TIP: use your tranny input shaft to center your clutch plate on the flywheel housing BEFORE you install your engine..... ...Dell
