Hydraulics I think I found it now what
CATFIXER
09-26-2004 10:27:16
Thanks for all the repeated posts on hydraulics I took the right side cover off and saw the pump was working with the lift raised I could see a pretty good flow of oil coming out of the back of the lift piston and obvious scratches on the piston now ehat could someone walk me throught removing the piston cover etc what parts should I have on hand etc
souNdguy
09-26-2004 11:10:31
 Re: Hydraulics I think I found it now what in reply to CATFIXER, 09-26-2004 10:27:16
I did htis job 2 months ago.. search for my posts.
All parts were less than 90 bucks, including shipping, a new relief valve, and a brake hone from napa. I re-used my cylinder.. but put in a new NAA piston/oring/washer. I did my pump as well.. If you aren't doing that you should be able to get in and out for about 50$ and a half day of casual work.
You'll need the 3 small top cover/cylinder gaskets.. the top cover gasket, and inspection cover gasket, and follower pin.
Pull the bolts around the perimiter out only.. remove top cover.. then remove the 4 bolts holding the cyl in.
good luck.. it isn't a hard fix.. just time consuming.. and dirty.
Soundguy
Dell (WA)
09-26-2004 10:42:48
Hey Spayed..... ..what? you don't have your own personal copy of the I&T FO-4 manual yet? $27 cheap.
It should be intuitively obvious that you will need a new topcover gasket. And the hydraulic cylinder pressure input gasket. Recommend the new and improved NAA hydraulic piston with "O"-rings.
Recommend you inspect and probably need to replace your cam follower pin. Recommend you do some "archive" searching at the top of this great N-Board.
respectfully..... ...Dell
CATFIXER
09-26-2004 10:49:56
 Re: Hydraulics I think I found it now what in reply to Dell (WA), 09-26-2004 10:42:48
Thanks DELL I do have the manual and I have read it allways looking for new tips not in the archives
you guys have all the secrets
I do work at a CAT house
not a brothel just a CAT dealership
I have found over the years its allways better to talk to someone who has done a particular repair to find those little secrets
Rob
09-26-2004 11:03:07
 Re: Hydraulics I think I found it now what in reply to CATFIXER, 09-26-2004 10:49:56
You get ready to lift that heavy cover without a hoist then lift the front a little and stick a 2x4 under there. Do the same with the back. Do it again to get te front 2x4 on edge and your lift control should be clear of the pump so when you grab hold and LIFT HARD stuff won't hang and get bent up.
Go back in the same way with blocks and you can go and control the last 3" real easy.
You got $90 replace the cylinder and replace the 3 piston rings (reuse the piston). You can't afford that then 2nd best is hone the old cylinder, new piston, and oring ($25 if you have a hone).
CATFIXER
09-26-2004 11:12:12
 Re: Hydraulics I think I found it now what in reply to Rob, 09-26-2004 11:03:07
Thanks for the info may try to put it off until it wont raise my box blade good but I know what I need to do trying to keep 3 n tractors and 2 old dozers running gets expensive and very time consuming heres a tip for you CAT part #4n669 is an exact replacement for the intake to carb gasket they cost .89 at your dealer and are made of heaver material they may even give you one or several
Rob
09-26-2004 11:27:07
 That fluid is mild EP GEAR OIL in reply to CATFIXER, 09-26-2004 11:12:12
Rob
09-26-2004 11:25:02
 If you're using that 134D universal fluid in reply to CATFIXER, 09-26-2004 11:12:12
you might replace it with the heavier M-4864A & B, SAE 90 above 32-degrees, SAE 80 below 32-degrees (if slow is a problem). The heavier fluid won't get by the worn rings/cylinder so fast.
Thanks for the tip.
