NAA with Bailer
SS
09-28-2004 07:50:22
Will an NAA with Hi-Lo transmission and live PTO, run a small square bailer, like a Massey 9 or 10? Thanks.
Bill(Wis)
10-01-2004 12:48:47
 Re: NAA with Bailer in reply to SS, 09-28-2004 07:50:22
Does your NAA have live PTO? It must be a 660 then. Just curious because, as far as I know, the Jubilee/NAA did not have live PTO.
souNdguy
09-28-2004 12:22:23
The sherman won't be a factor.. run in direct. The live pto will be a great help.
Soundguy
txblu
09-28-2004 09:29:26
Should, as long as the rocking motion caused by the ram going back and forth doesn't put you to sleep causing you to fall off the tractor.
The real work is done by the flywheel. All the tractor has to do is drag the weight and spin the wheel.
Live PTO definitely helps you to get out of tight situations. I personally wouldn't bale without it or independent, but there are visitors here that do.
Mark
