Flathead Engine: car/truck vs. tractor
SCE
09-28-2004 10:54:38
I pick up N engine parts as I find them, and have wondered if the automotive flathead engine and related parts will interchange. Does anyone have a working knowledge of what will swap over?
Dan Yocom
09-29-2004 04:38:07
 Re: Flathead Engine: car/truck vs. tractor in reply to SCE, 09-28-2004 10:54:38
Does this mean that a V8 head will fit the N's? Since the funk Hi compression heads are hard to come by maybe a V8 Hi comprssion head could be used?
no . . . Dell (WA)
09-29-2004 08:25:28
 Re: Flathead Engine: car/truck vs. tractor in reply to Dan Yocom, 09-29-2004 04:38:07
Yocom..... ...the N-Engine is 18-bolt head, the V-8 flatheads are 21-bolt heads. It should be intuitively obvious, they ain't gonnna swap. I do "love" the finned head look of "Offy" alumnium heads onnna fulldress flathead V-8..... ..Dell
ZANE
09-28-2004 17:43:46
I think the pistons will interchange with the N engine.
The connecting rods for the Ford V8 engine before 1949 will definately not interchange since the old V8 flat head rods shared one set of two halves of connecting rod inserts that floated in the two rods that shared the inserts on the one throw. The rods turn on the OD of the insert and the crank journal turns in the ID of the insert.
I don't think the 1949 through 1953 rods will interchange either because they are for either the back of the throw or the front of the throw. You can put the left bank rods and pistons in any hole on the left bank and get by with it but you can't put the left bank rods on the right bank. This is because the rods are slightly off center of the piston.
Zane
Packrat
09-28-2004 12:37:08
Found this in the Archives...
Sounds like a book worth owning.
" The FORD N SERIES TRACTORS ORIGINALITY GUIDE by Chester Peterson Jr. and Rod Beemer, page 26, says that in addition to the "L" head being half of the automobile V8, the timing gears, intake valves, and other internal engine parts all came out of the Mercury V-8 parts bin. Starters for the 9N and small V-8 were the same. Large Ford trucks and the 9N shared the same rear axle rings and pinion gears."
-Packrat
raytasch
09-29-2004 18:32:08
 Re: Flathead Engine: car/truck vs. tractor in reply to Packrat, 09-28-2004 12:37:08
The mentioned book is full of inaccuracies. Very few internal engine parts are interchangeable between the N engine and the Ford V8.
ray
JimTN
09-29-2004 09:47:41
Pistons from Ford work, intake valves, guides, lifters, timing gear, starter and drive from 17-40 60HP v8, points from dist.
MikeT
09-28-2004 11:47:07
The Ford flathead 6 used in F1 pickups and some cars was used in the Funk conversions for 9N, 2N, and 8N tractors.. Mostly G or H series 226, 90 or 95 hp.
Mine is the 1951 H series.
