Not complete lift
Rocky
03-06-2001 15:18:47
The three point on my 48 8n doesn't lift all the way up and sometimes moves up kind of jerky. Is this a common problem? With hopefully an easy fix?
Thanks,
Rocky
ZANE
03-06-2001 17:51:20
 Re: Not complete lift in reply to Rocky, 03-06-2001 15:18:47
The lift on the 8N really needs a jig to be adjusted correctly the first try.
I have the jig and booklet to show how to adjust the lift with it.
See the link below
peterc
03-06-2001 16:53:29
check the fluid level first if it is good the problem is in the control linkage, you may have to take the lift cover off and adjust the linkages. ggod luck
