Order Ford 8N Parts Online
Needs for rear tires on 8N to plow snow.
Tom Schulein
10-04-2004 05:02:32
I am going to buy or make a FRONT mount blade for my 8N.
I have received conflicting messages from reviewing previous postings.
One message said forget the chains, as they are not necessary.
Another said, I must have liquid in my rear tires.
Are both needed? Is only one needed? If one, which is best.
I will be plowing a level driveway in Iowa and we can get from 2 to 10 inches of snow, mostly in the 4 inch range, I would say.
Also, I may wish to take the tractor up and down my street, which is fairly sloped, to do a neighbor's.
Thanks, Tom
BillM (OH)
10-04-2004 08:14:35
 Re: Needs for rear tires on 8N to plow snow. in reply to Tom Schulein, 10-04-2004 05:02:32
Chains are a must & should be sufficient. Loaded tires are a pain.
larry 8N75381
10-04-2004 07:41:19
Tom,
I "plowed" snow here in Va. one year when we had something like 18 inches. And it is almost always wet out here, not like in Iowa where it can be dry and fluffy. (Shoveled snow in Ames for my room when in college.) I used my Ford 3000 and back blade. Found that backing into the snow and then lifting the blade worked great. Sort of like rolling a snow ball. My tires are unloaded and I didn"t have chains.
I did get stuck trying to drive forward into some deep snow. Being wet it "bunched" up and got stiff enough under the belly that it lifted the tractor up enough that I lost traction. Don"t know if chains would have helped in that case. My experience is that chains are the best thing you can have next to NO snow. :-) Only used chains once in Iowa but they were the difference in being stuck and needing to get towed out, and my getting out on my own.
To answer your question, I"d get chains as the first thing to try not fluid in the tires. And if you think you need extra traction, put something on the lift that you can add weight to. If you didn"t have an N, with it"s high speed reverse, I"d suggest using a rear blade for the weight. Then you could push snow "both" directions if you wanted to. You will have to try out things to see what works best for your situation.
Regards,
Larry
John Smith8N
10-04-2004 07:23:19
I've got a set of rear tires that would be just the ticket for your needs. Click the link below, third item on the page.
ericlb
10-04-2004 07:11:38
hi tom, in my experience you will need at least chains, i took the ford 2000 with a fel on it out snow plowing last year, its mountainous country here and i just had unfilled naked tires, but good ones, that was a bad idea---really bad idea, that thing was a skate, had very little control on pavement, it spun the wheels all the time although it did ok off road, just my experience, ericlb
Rob
10-04-2004 06:17:25
 How many times you want to hear in reply to Tom Schulein, 10-04-2004 05:02:32
the arguments pro and con. It's your tractor, make up your mind and go ahead. Have fun.
