Sherman backoe
Powerdigger
10-04-2004 14:46:14
Posted this in the new forum the other day but it seems to be out of commision for a while so I thought I'd try here.
My Sherman Power Digger on my 9N loses pressure and slows down after running it for a while. Top pressure is around 1500, and if I hold a valve open under load the pressure starts dropping. The more I work the unit the slower it moves and the less pressure I get. Stumpy suggested I pull out and block off the relief valve and test to see if the pressure still drops, which I haven't yet had a chance to try.
Does anyone know what pressure the Sherman is supposed to operate at, and how it behaves? In other words, if 1500 is the max, is it supposed to hold at 1500 under load, or drop down to some other value?
Russ in SoCal
10-04-2004 23:58:49
 Re: Sherman backoe in reply to Powerdigger, 10-04-2004 14:46:14
PD,
I"m not familiar with the workings of them critters. N-news archives has an owner"s manual available for one of the Sherman models. Check the link and see if it would be worth getting.
