2N timing
Gary Prestridge
10-05-2004 19:50:53
How do you know if the points plate (timing adjustment)is in the right position..Saw somewhere a picture and explanation of how to check/measure position of the lug on the back of the distrib. just as the points are beginning to open...Who can explain?? Thanks
Rob
10-06-2004 05:13:52
 Jazzed up the pic some. in reply to Gary Prestridge, 10-05-2004 19:50:53
third party image
Now I can read it.
Gary Prestridge
10-06-2004 17:52:55
 Re: Jazzed up the pic some. in reply to Rob, 10-06-2004 05:13:52
Picture did not show for some reason--only small box with red X
Rob
10-06-2004 03:46:15
 Re: 2N timing in reply to Gary Prestridge, 10-05-2004 19:50:53
third party image
Set it at 1/4". Do not rotate CCW to set point, CW only. If you go past 1/4" then don't back up, just go on around again. The backlash will foul you up.
Gary Prestridge
10-06-2004 04:09:59
 Re: 2N timing in reply to Rob, 10-06-2004 03:46:15
Rob, thanks..another Dwg I had seen just was not clear enough to see the position of the tang and exactly where and how to measure..Thanks again
Dell (WA)
10-05-2004 20:12:55
Gary..... ..whats to explain? Picture is morebitter than words. The frontmount 2-bolt distributor is driven by an "off-set tang" scheme. You doubt? Taker off and lookie-look. Instructions were quite well written. Iff'n yer distributor rotor don't eazily drop into the camshaft slott, yer doin' sumptin WRONG.
And NO, there is NO-WAY to time the frontmount distributor with a ignition timing light..... ....respectfully, Dell
Gary Prestridge
10-06-2004 04:05:29
 Re: 2N timing in reply to Dell (WA), 10-05-2004 20:12:55
I found the drawing again last night on Nseries discussion but the picture just isn't clear..Maybe its my monitor or the fact that I'm more than half blind..Rob sent a drawing/picture that is very well done ..Thanks
