Drain plug
Dale (NY)
10-06-2004 15:22:05
Does anybody know the size of the small drain plug under the diffy?
GrandSlam
10-06-2004 18:43:12
 Re: Drain plug in reply to Dale (NY), 10-06-2004 15:22:05
3/4" I think. I'm someone who KNOWS will help out.
Dell (WA)
10-06-2004 18:53:53
 Re: Drain plug in reply to GrandSlam, 10-06-2004 18:43:12
its p/n 353064-S8, 1/2" pipe thread (NPT), extended square head.
Always drain your squarehead diffy oil plug first 'cuz it pees with some accuracy; then drain the 3" tranny plug; then drain the 3" hydro-pump plug. Fill'em-up by tranny shifter, 5 gals of Ford/New Holland recommended spec: M2C-134D hydro-tranny oil. ($25, cheap) 'Course you can also use the 1939 spec: 90wt mineral gear oil, iff'n you can find it. GL-1 is close, but DON'T USE GL-4 or GL-5 'cuz they contain EP additives unfriendly to your hydraulic pump guttz..... ....respectfully, Dell
gahorn
10-06-2004 21:52:33
 Re: Drain plug in reply to Dell (WA), 10-06-2004 18:53:53
Ford allowed the use of "mild" EP gear oils in the N-tractors, and I'm convinced that equates to the GL-4 stuff. I believe it was Zane who stated he's seen GL-5 in these things for decades and no harmful effects. Exactly what specific parts are made of "yellow" metals in these N-Fords?
souNdguy
10-07-2004 04:27:31
 Re: Drain plug in reply to gahorn, 10-06-2004 21:52:33
Hydro pump internals.. ( biggest problem is there is no source of new parts.. once your cam blocks wear..you have to try to find others via salvage...). It is well documented, from some of the major oil companies that gl-5 oils can damage yellow metals. A link was posted a while back from ?penzoil? atesting to this fact.
Soundguy
Rob
10-06-2004 17:11:41
 MPC says 1/2. in reply to Dale (NY), 10-06-2004 15:22:05
