Order Ford 8N Parts Online
valve tools for 8n
mike mix
10-06-2004 15:53:12
Trying to remove the valves from my 8n.Does anyone know where to purchase the special tools Ford dealers use to remove the valves? The Valve Lifter "6505-A" and the Jack-type lifter. Or any suggestions on how to remove the valves. Thanks for the help. Mike
Hobo,NC
10-06-2004 17:46:10
 Re: valve tools for 8n in reply to mike mix, 10-06-2004 15:53:12
Go to ebay and on the top right of page type in valve spring compressor. I see them go fer less than $20 bucks all the time, so cheap everybody should have one
Rob
10-06-2004 17:07:33
Sears sells the c-type spring compressor Hobo uses. I have a 24" prybar modified slightly to narrow the tip rather than the screwdriver. Sometimes that isn't enough.
End up busting the guide to get it out. Talking hammer and chisel now. No great loss.
Good pictures Hobo.
Hobo,NC
10-06-2004 16:51:55
third party image
installed in port
Hobo,NC
10-06-2004 16:49:38
third party image
automotive type spring compressior used to remove valve and spring then you can drive the guide down and remove the retainer
Hobo,NC
10-06-2004 16:47:19
third party image
Bent screw driver used to puch down guide so you can remove retainers
