Order Ford 8N Parts Online
8N brake sticking
Peter
03-07-2001 09:52:23
When I plow snow, I have to use the left brake a lot to help turn. The brake seems to stick sometimes, even if the brake pedal is back up, either by itself or because I reach down and pull it. The undesired left wheel drag makes it easy to get stuck, because the right wheel spins and the left one doesn't get enough power unless I brake the right one, and this is not a good long term solution. Is there a quick fix or short term wintertime solution to this problem? Here in central NY, we have a lot of winter left.
Steve IA
03-07-2001 10:04:13
 Re: 8N brake sticking in reply to Peter, 03-07-2001 09:52:23
The left brake has 2 springs. One may be missing, unhooked or broken. Pull the brake drum and check. Hopefully this is all your problem.
HTH Steve 8N 169302
