Order Ford 8N Parts Online
8N Carb Problem
Steve T
10-10-2004 12:49:15
My 8N will crank but will not start. After a few rotations fuel will run out of the vent at bottom of carb. I replaced the float needle and seat and all new gaskets, but it still does the same thing. I am getting fire, so I don't know what to try next. I would appreciate any suggestions
Dell (WA)
10-11-2004 07:06:57
 Re: 8N Carb Problem in reply to Steve T, 10-10-2004 12:49:15
Steve..... ..while your carb leakage could be incorrectly adjusted float level, I suspect it is more a question of inaddaquate sparkies.
PROVE that you don't have a sparkie problem instead of a carb problem.
Make a "calibrated sparkie tester" by taking enny old sparkplug and bending the side electrode out for a gap of 3/16" (0.1875"). Clamp the metal shell to the engine block. Then plug enny sparkie wire onto the top of yer sparkie tester and cranker-over. Does yer sparkie jump the 3/16" gap with blue snott authority. Yes? then you've gotta carb problem. NO? then you have sparkie problems..... ...respectfully, Dell the self-appointed sparkie-meister
bill tinklepaugh
10-10-2004 18:04:57
i have this same problem. thought it may be a slow cranking problem. when the tractor is jump started --- it fires right up.
uh . . . Dell (WA)
10-11-2004 07:02:03
 Re: 8N Carb Problem in reply to bill tinklepaugh, 10-10-2004 18:04:57
Bill..... ...Iff'n ya gottza problem, be brave and start your very own question, instead of hideing inside someone elses non-related problem question. We don't charge for answering your question and you might just gitt the right answer faster.
PROVE that you don't have a sparkie problem instead of a carb problem. Make a "calibrated sparkie tester" by taking enny old sparkplug and bending the side electrode out for a gap of 3/16" (0.1875"). Clamp the metal shell to the engine block. Then plug enny sparkie wire onto the top of yer sparkie tester and cranker-over. Does yer sparkie jump the 3/16" gap with blue snott authority. Yes? the you've gotta carb problem. NO? then you have sparkie problems..... ...respectfully, Dell the self-appointed sparkie-meister
Tymoc
10-10-2004 17:05:04
Sounds like it.
Rob
10-10-2004 13:20:07
 It's likely you give it way too much choke. in reply to Steve T, 10-10-2004 12:49:15
You only need to bump the choke some. In warm weather you don't need any choke.
Eeeeee asy to flood the N.
Spray some starter fluid in there and crank it. If it fires you probably have spark. You want a snappy, blue spark and a nice, yellow spark won't do.
Steve T
10-10-2004 16:39:16
 Re: It's likely you give it way too much choke. in reply to Rob, 10-10-2004 13:20:07
I thought that at first, but it runs out even if I don"t choke it.Could it be the float needs adjusting?
Rob
10-10-2004 17:26:48
 Could be the float. in reply to Steve T, 10-10-2004 16:39:16
Is there gas in intake before you try to start it? If the float valve is leaking it will leak all the time and not just when you try to start.
