Rusted froze driveshaft
8ngreenhorn
10-10-2004 18:17:40
The driveshaft is frozen to the shaft on my bush hog. A sledge and a lot of cussin' don't work.
souNdguy
10-11-2004 07:17:54
 Re: Rusted froze driveshaft in reply to 8ngreenhorn, 10-10-2004 18:17:40
You don't have any remnants of a shear pin left in there do you? Or any galling where a shear pin expired? Also.. some driveshafts are held on by a split ring for when the shear pin dies.. make sure the split ring is out.
Ohter than that.. pb blaster, and go out and tap it with a hammer on all sides about every 15 minutes.. rotate and tap. Don't bang hard enough to damage your bearing/ seal in the gear box.. just enough to loosen rust.. etc
If it comes down to a point where it just won't come off.. and the gear box/mower is good.. take a hack saw or a die grinder/angle grinder, and cut the yoke off. Cut into it but stop before you hit the mowers shaft... do it on opposite sides.. or even 4 sides.. should make it pop right off.. or at least open it enough for you to cold chisslle it off without harming the mower bearing/seal/shaft. Then you'll need to get a ney yoke end and slap on the u-joint.
If the shaft is galled or pitted.. dress it very well with emory paper, or a file for large raised galls. get it buttery smooth with fine emory paper/cloth before you slide another yoke on there.. lube it to. Try to just dress the surface.. you don't really want to remove material to significantly lower the OD of the shaft, as the shaft to yoke may wobble.
Soundguy
Rob
10-11-2004 02:37:02
 You need a back-up. in reply to 8ngreenhorn, 10-10-2004 18:17:40
Get another hammer. Put that sledge or another chunk of iron on one side of the coupler and wail on the opposite side. A heavy pipe wrench would probably do. Get the coupler between a hammer and anvil. Rotate the coupler 90-degrees and do it again, 90-degrees and again, and work it over until it comes loose. Won't take long.
old
10-10-2004 21:14:05
I'd try some heat unless its to close to the gear box. If it is, I'd pour some oil, PB blaster etc on it for a couple days
