Drawbars
R.M. In AL.
10-11-2004 19:37:48
Is there a standard drawbar length.I noticed that TSC has different lengths.Which one is best and about what should the price be.Thanks for any response...R.M. In AL
Rob
10-12-2004 02:58:39
 The N 3-pt is category 1. in reply to R.M. In AL., 10-11-2004 19:37:48
TSC also carries category 0 drawbars the standard on garden tractors and cat 2 drawbars for tractors larger than the N. The 'category' standard spells out length, pin size, ball socket size, etc. If you know the category of the hitch you can buy pins, stay straps, balls, and even impliments without measuring to compare. If the category is the same then it fits.
A cat 1 drawbar will fit tractors with 26" lift arm spacing and 7/8" ball sockets. It will have 3/4" hitch pin holes.
