Zane Thang helping hand.
Paul (WI)
03-07-2001 18:09:09
I would like to mention a couple of instances where the Zane Thang is very useful. When you are at the rear of the tractor hooking up a 3 point implement and the lower arm has to be adjusted to a different height, just reach over and move the Zane Thang rod slightly to raise or lower the arm. This saves a trip or two around the back wheel to move the control arm. The lower arm will stay right where you put it and will make the hook up much easier. Another place that it performs well is when using a boom pole. It makes this a much safer operation because of the control that you have.
