Does't fire
qm
10-15-2004 11:23:08
My 8N has been running fine(TKs for suggesting a new coil)+(oil pressure improved with 20-50 oil). Now it turns over with starter, but won't fire except for an occasional "putt". Gas is good. Starter is good. Yesterday, while coming up with a load of wood, it almost stalled out suddenly but "grabbed" on again and came home. Is this a condenser? Or? Bob
QM
10-15-2004 14:55:39
 Re: Does't fire in reply to qm, 10-15-2004 11:23:08
TKS Dell- I gently pulled the coil contact wire and tightented the fit of the coil on the dist. You were right its a front mounted. And she fired! And I got a load of very dry wood up before it rained! rough woods roads! Bob
Dell (WA)
10-15-2004 11:57:19
Bob..... ...most sudden loss of sparkies is usually loose wire connection somewheres. I'm gonna guess that you have the squarecan frontmount distributor. And while it could be a loose/bad condenser you can tell by looking at your ignition points. Based upon your minimalist description of your problem, I'd guess that the springy-thingy under your squarecan ignition coil needs to be gently stretched to make a more positive contact with the gutts of the distributor. Then I'd check the gap of the frontmount points 0.015"..... ..Dell
