Order Ford 8N Parts Online
8N snowplow for 640 update
Hotdog
10-18-2004 18:03:57
third party image
well I bought it, all I need to do is make a new L-bracket for the rear axil and I should be good to go. I plan to clean it up and repaint it before mounting it. Is it a Dearborn I included a pic but it's the 1st time, how do you list multiple pics?
Thanks for the advice!
Let it snow,Let it snow,Let it snow,!!!
Frank
Upper Peninsula,Mi
10-20-2004 11:11:39
 Re: 8N snowplow for 640 update in reply to Hotdog, 10-18-2004 18:03:57
third party image
Here's a picture of a Dearborn on my 9N
Upper Peninsula,Mi
10-20-2004 11:17:25
 Re: 8N snowplow for 640 update in reply to Upper Peninsula,Mi, 10-20-2004 11:11:39
The picture doesn't show the weight added to the rear. I used a 16 gal.barrel and filled it with concrete. All told including welding the attachments on the barrel and a few small things the extra weight came to 320 lb. I normally drive in high gear, some times in 2nd or low with the Sherman overdrive in gear. Works like a dream. My email is uncovered if you wish to communicate. Ron
Leroy
10-19-2004 05:52:22
I have no idea what make it is BUT it is not a Dearborn-Ferguson as they had a round tube frame, not angle iron as this one has, I see it has a hitch on back that will come in very handy, I believe that it may be a very well built homemade unit, would like to see more details pictures
Jim.UT
10-18-2004 20:52:30
 Multiple pics in a post in reply to Hotdog, 10-18-2004 18:03:57
To put more than one pic in a post, don't use the "optional image URL" box. Instead you need to use some html tags within the text of your post. Here's an example:
(img src="http://www.photosite.com/mytractor.jpg")
Now instead of "(" and ")" use "<" and ">". If I had used the correct symbols in my example, the computer would have thought I was trying to post a pic and after failing to find my ficticious website would have given the "dreaded red x" (aka DRX).
You can use the above tag as many times in a post as you like, but if you go overboard and post too many pics your post will take forever to load.
Another caution: sometimes pictures are too big for a computer screen. To limit the size of the picture you want to display, add a little sizing language at the end of your image tag. Like this:
(img src="http://www.photosite.com/tractor1.jpg" width="500")
Then after you hit the "Submit" button look at the picture. If it's still too big, hit your back button and change the width to 450 or 400.
Hotdog
10-19-2004 17:40:08
 Re: Multiple pics in a post in reply to Jim.UT, 10-18-2004 20:52:30
Pic of plow do these help ID
img src=http://216.167.44.209/programfiles/talers/Plowback.jpg
img src=http://216.167.44.209/programfiles/talers/Framereaview.jpg
img src=http://216.167.44.209/programfiles/talers/Framefrountview.jpg
uh . . . Dell (WA)
10-19-2004 18:24:09
 Re: Multiple pics in a post in reply to Hotdog, 10-19-2004 17:40:08
HotDog..... ....ya forgotts the lessthan (<) and morethan (>)..... ..Dell
third party image
third party image
third party image
jrd
12-31-2004 05:57:51
 Re: Multiple pics in a post in reply to uh . . . Dell (WA), 10-19-2004 18:24:09
