Zane Thang or Front Pump?
alpacafarmer
10-19-2004 14:18:17
Hi, I have an 8N with an old superior trip FEL which runs off of the internal hydraulics. You guys know that I have to chain down the 3pt and am not able to use anything else on the 3pt while using my loader. Would the Zane Thang solve this problem or do I need a front hydraulic pump. I am new to the 8N world but I"m enjoying learning from you all. Thanks very much, Dave
Barry8N
10-20-2004 07:12:18
 Re: Zane Thang or Front Pump? in reply to alpacafarmer, 10-19-2004 14:18:17
Anyone have pictures of a front pump assembly mounted on the tractor we can use for reference?
Dale (NY)
10-19-2004 16:10:39
If your going with the front pump count on ~$700 fir parts. This includes 3 D.A. cylinders, pump, mount, stinger shaft, pulley & hub, 2 spool valve w/float, hoses and fittings. Its an expensive little endeavor that I just recieved my parts for. I think itll be worth it to not have to chain the lift.
jackie finch
10-19-2004 16:28:11
 Re: Zane Thang or Front Pump? in reply to Dale (NY), 10-19-2004 16:10:39
hey , Dale (NY ) I did not know the front pump and related items can still be purchased ? where can I get them ? Jack
Hobo,NC
10-19-2004 17:32:30
 Re: Zane Thang or Front Pump? in reply to jackie finch, 10-19-2004 16:28:11
third party image
You can still get all the parts. The main part you will need is the front mount that the pump sets on and bolts to the axle support. They are not avalible and you would have to make it.
John IL
10-19-2004 14:31:16
Hey Dave,
The Zane Thang wouldn't solve your problem, but the Zane Live Thang would. The Live Thang adds live hydraulics to your 3-pt lift. And, you can route the pressure line through a spool valve to control your FEL independant of the rear lift. The Live Thang isn't as strong and fast as a front mounted stringer pump, but you don't have to permenently alter the tractor to use it. And, you get a live lift as a side benefit. I recently added one to my '51 8N and I love it.
John
alpacafarmer
10-19-2004 15:17:11
 Re: Zane Thang or Front Pump? in reply to John IL, 10-19-2004 14:31:16
John, when you say I would have to premantly alter to use the front pump what are you refering to? I have seen other 8N's with the front pump and they have the grill off, is that what you meant?
Thanks again, I really appreciate it, Dave
lonestarjeff
10-19-2004 18:24:14
 Re: Zane Thang or Front Pump? in reply to alpacafarmer, 10-19-2004 15:17:11
You can also get an aftermarket grill for $30-$50 on ebay to cut the hole in & use when the front pump is mounted.
Jeff
Jet9N
10-19-2004 16:46:11
The usual way was to cut a hole in the grill. I
don't think you'd want to do that any more. I would make a grill out of expanded metal or some
thing similar rather than cutting the grill. Use
temp grill while pump is on. I know some loaders have a grill on them that cover the front quite
well so this would not be needed.
Jet
