Anti-freeze leak by starter motor
9N Rob
10-22-2004 04:59:35
I have what appears to be an anti-freeze leak from behind the starter motor on my 9N. I am certain it is not leaking from the drain plug on the left side of the engine. Does the top (left side?) of the starter motor attach to the engine block where anti-freeze circulates? What can I check/do to correct?
Thanks!
raytasch
10-22-2004 06:38:39
 Re: Anti-freeze leak by starter motor in reply to 9N Rob, 10-22-2004 04:59:35
Replace the "freeze plug" in the block behind the starter. If one is gone the others are probably ready to go.
ray
Dell (WA)
10-22-2004 07:19:15
 Re: Anti-freeze leak by starter motor in reply to raytasch, 10-22-2004 06:38:39
Rob..... ...what Ray sez..... .them roundy disc things (1-3/16) in left side of block (3 ea) are commonly called "freeze-plugs" but don't. They're really for shaking the sandy core out of engine after being cast with MOLTEN IRON and cooled. Iff'n you don't understand how to install a new freeze-plug, ask..... ....Dell
